Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Drive Shaft AOD Transmission
Old 04-03-2002, 05:21 AM
melbishop melbishop is offline
New Member
Post Drive Shaft AOD Transmission
Is the two speed fordamatic the same length as the AOD Transmission? Will the length of the drive shaft have to be modified for a swap? INFO NEEDED THANK YOU.
