-   -   Drive Shaft AOD Transmission (http://www.hotrodders.com/forum/drive-shaft-aod-transmission-8769.html)
melbishop 04-03-2002 04:21 AM
Is the two speed fordamatic the same length as the AOD Transmission? Will the length of the drive shaft have to be modified for a swap? INFO NEEDED THANK YOU.
mustang66maniac 04-03-2002 08:01 AM
The AOD is longer, you will need to shorten your drive shaft.
