Drive Shaft AOD Transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2002, 04:21 AM
New Member
Post Drive Shaft AOD Transmission
Is the two speed fordamatic the same length as the AOD Transmission? Will the length of the drive shaft have to be modified for a swap? INFO NEEDED THANK YOU.
Old 04-03-2002, 08:01 AM
mustang66maniac's Avatar
Ford Freak
Post
The AOD is longer, you will need to shorten your drive shaft.
