drive shaft collar 79 camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2013, 07:43 AM
Hi guys, I started getting a rattling sound almost like rocks in a can as soon as I would engage the drive shaft. Last night I jacked up the car and finally found the problem. It is a plane non gasket ring collar that is loose. It looks like a "dust" collar where the drive shaft goes into the bell housing. I was wondering what this actually is/does, and also any suggestions as to how to keep it secured. I am thinking just using rtv as a glue to keep it off the drive shaft. Thanks in advance-
Old 05-11-2013, 08:31 AM
big gear head's Avatar
High Performance Rear Ends
It's a guard to keep rocks and dirt away from the pinion seal. They are presed on and staked from the factory and they do get loose sometimes. You can try the RTV and see if it holds it in place, but I doubt that it will work for long. You can remove it, but that requires removing the yoke from the rear end and that can be tricky. I can't tell if that is oil on the botom of the rear end or if it's black paint. If it's oil then it looks like you need to replace the seal anyway.
The Following User Says Thank You to big gear head For This Useful Post:
sugarayny (05-11-2013)
Old 05-11-2013, 08:32 AM
Banned
photo is tiny, and looks like a shot of the rear axle pinion
Old 05-11-2013, 08:35 AM
Its undercoating that was put on after the floor pans got replaced. I never want to do that again lol.
drive shaft jamesjohn Transmission - Rearend 1 12-19-2012 06:26 PM
drive shaft help hotpepper Transmission - Rearend 1 08-21-2007 05:39 PM
Drive Shaft?? APalusky Transmission - Rearend 15 02-08-2007 06:24 AM
Drive Shaft street rodder 1937 Transmission - Rearend 3 10-17-2003 03:02 PM
drive shaft squiggy2000 Transmission - Rearend 3 02-11-2003 10:26 PM
