Drive shaft end play
Just put in a 700r4 in my 78 Camaro,went out to the local pick&pull an got a drive shaft from a Mustang. Needed to be 45 1/2 long witch it is. Sorta did a per install just to make sure it fit an it does but theirs no end play.The output shaft from the trans is against the base of the slip yoke.Shouldn't their be about 1/2" of play? Wheels are off the floor,rearend supported on the axle tubes,front end I have stands supporting the frame not lower a arms.For now I'm using the TH350 slip yoke.Should I have the drive shaft cut shorter?
a buddy and me just had a drive shaft built for an s10 with 700r4 and ford 9".we used a 3/4" play in the shaft.thats what the shop recomended.it works great.
Everyone's on the same page here, I have 3/4" in a 4-link coil over setup, very little suspension movement up and down, but that's what the end play clearance is for.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
| how much drive shaft play? | Hwyhogg | Transmission - Rearend | 17 | 12-07-2010 11:39 PM |
| Turbo 400. Leaks/Drive Shaft Play. | hunk-a-junk | Transmission - Rearend | 2 | 10-01-2008 04:43 PM |
| qjet throttle shaft play | mhamilton | Engine | 15 | 12-28-2006 03:44 PM |
| How much Tail Shaft Play??? | Not A T 25 | Transmission - Rearend | 9 | 06-22-2006 08:01 PM |
| HEI shaft play | adryan16 | Engine | 6 | 03-21-2004 07:58 PM |
