drive shaft help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2007, 06:04 PM
drive shaft help
I recently put a sbc 350in a 86 camaro with a yh350 transmission.
here is my problem, i need to find a drive shaft that will work with that tranny
and stock rearend. can anyone help??
tahnks
Old 08-21-2007, 06:39 PM
Tyler
Take the original drive shaft from the car and a buy a driveshaft from the junkyard with the right end for the transmission. There should be a fabrication, or machine shop in your area that makes driveshafts. I won't explain how to measure because each shop has different preferences. I will tell you this. You have to measure with the car sitting with all four tires on the ground just like when it's driven. (not on jack stands etc.) Locate a shop and ask them how they want you to measure and show them what you have and tell them what you need. It might even be better to talk to them before you buy anything from the junkyard because some shops can order the ends that you need brand new. Don't be succered by a shop that has a welder and cutting torch that said they can help you. The shop that makes my driveshafts put's the driveshaft in a mettal lathe and uses a dial indicator to make sure that it is straight and has no high spots after welded. He uses a torch and an air hose to heat and cool in ceartain spots to lower high spots and raise low spots. He also balances it , but I've never seen him do that part of it. Good luck. jtyler
drive shaft removal stu_yoakam Transmission - Rearend 13 04-02-2007 03:01 AM
Drive Shaft?? APalusky Transmission - Rearend 15 02-08-2007 07:24 AM
crossmember and drive shaft trouble rbaughman Hotrodding Basics 6 04-06-2005 05:17 PM
drive shaft lenths 37jim Transmission - Rearend 5 12-11-2003 02:04 AM
St-10/ 2 piece drive shaft question 85406 Transmission - Rearend 1 04-16-2003 02:36 PM
