drive shaft length - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2011, 08:22 PM
drive shaft length
i have a 1969 nova with s chevy 350 turbo transmission. the drive shaft yoke in it sticks out about 2" at the rear of the transmision. i know it should be about 1" but is this ok. it still have about 3" of the transmission shaft in it
Old 08-24-2011, 09:43 AM
S10xGN's Avatar
Gotta love a turbo!
"OK" as long as you don't have any driveline vibration. That said, I wouldn't run it hard. By virtue of having less of the splines engaged, they're more likely to twist if abused.
Russ
Old 08-24-2011, 10:01 AM
Usually, as long as the splines are not sloppy and there is at least 2-1/2" of spline engagement, should be OK if you have some form of traction bars. If it's got weak monoleafs, i might want at least 3" of static engagement as the yoke will use more travel.
Drive shaft length for 96 s10 v8 swap eric32 Transmission - Rearend 5 07-07-2009 04:03 PM
drive shaft length 48aero Transmission - Rearend 5 03-08-2009 11:24 AM
drive shaft length racer rick Transmission - Rearend 2 02-20-2009 09:23 AM
Drive Shaft Length 71 c-10 Suspension - Brakes - Steering 7 10-25-2007 02:53 AM
drive shaft length tack Transmission - Rearend 2 07-22-2002 02:06 PM
