Drive shaft length - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2012, 07:40 PM
Drive shaft length
I've got a 1950 Jeepster that I put in a 1994 chevy 4.3 V6 with a 1994 S-10 Blazer differential. I'm using a 2004R automatic transmission. I'm looking for a driveshaft with the following dimensions. With the slip yoke pulled out 1" the length from bearing cup center to bearing cup center is 42 5/8". The cups are 1 1/8" and the bearing cups measure 3 5/8" o/s face to o/s face. Does anyone know the model of something that will fit or something that can be cut down to fit? It sure would be nice if there was a website that gathered this info. to save us all from randomly spending hours measuring drive shaft lengths. Thanks for any help.
Old 05-21-2012, 07:45 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Most likely you will need to make a trip to the driveline guy and have one made up to your dimensions..
Sam
Old 05-21-2012, 07:50 PM
Cape Cod Bob's Avatar
http://www.dennysdriveshaft.com/how_to_measure.html
Old 05-21-2012, 07:53 PM
Wiki Edits: 27
Neel some luck.
I've had a 364 buick, with Ford t 85 Od, 401 buick auto, small block ford w/ 4 speed, SBC with jeep 4 x 4 trans, T case and stude Od all hooked together, finally blazer running gear,, about half the time I ve been able to use a tape measure and calipers and find one that worked. When looking for a drive shaft that has the right ends and just needs to be shortened I always look for one with No or minimum balance weights. It's easier to get rebalamced if the original shaft was well balanced to start with with min weight.
drive shaft length flerpy Transmission - Rearend 1 03-14-2012 08:39 PM
drive shaft length tbrown8338 Transmission - Rearend 2 08-24-2011 09:01 AM
drive shaft length 48aero Transmission - Rearend 5 03-08-2009 10:24 AM
Drive Shaft Length 71 c-10 Suspension - Brakes - Steering 7 10-25-2007 01:53 AM
drive shaft length tack Transmission - Rearend 2 07-22-2002 01:06 PM
