s 10 swap
I did a ranger 5.0 swap and a couple companies specialize in mini-truck V 8 and have a lot of Info..I don't remember which company I used but they had both ranger and s 10 kits and good info in the stuff they sent me.
The 700R4 is about 3" longer than a TH350 with 6" tail housing, TH350 with 9" tail is same length as the 700R4, so you may need a longer driveshaft. Or find a 82 and older S10 that came with the 200C trans so you can grab the crossmember and driveshaft. http://www.dennysdriveshaft.com/how_to_measure.html
http://www.maliburacing.com/auto_tranny_id.htm |
Most guys that install a V-8 in a S-10 , leave the drive shaft in place.
Bolt the new trans in place of the old so the drive shaft length is correct. This applied to the 1980's version of the S-10 , not sure about the 1990's design.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Well I hope it will work out that way all I knos is that on my 86 s10 my dad had to get another driveshaft from something else or something like that and he had to cut it and try to place it at different spots and use a dial gage to make sure it had proper clearance of some sorts. I don't know anything about driveshafts but man I would love to learn these things. Thanks guys for your help. I might eventually get new drive shafts for both of my trucks one of these days. Thanks again
Eric |
| V8 Beetle on S10 blazer chassis??? | zbhover | Hotrodding Basics | 2 | 10-25-2008 02:09 PM |
| 1992 s10 v8 4x4 swap | MIKE1521 | Engine | 1 | 04-09-2007 12:18 AM |
| Closed Drive shaft question | Jackyl | Transmission - Rearend | 3 | 06-05-2003 03:24 PM |
| 87 s10 v8 conversion | too__old_for_this | Engine | 5 | 11-23-2002 05:24 PM |
| front drive shaft in bronco 2 | steve norman | Transmission - Rearend | 2 | 10-19-2002 11:11 AM |
