Drive shaft length's chart? Is there one? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2012, 04:44 AM
Looking for a chart with drive shaft lenght's.
Old 01-29-2012, 05:40 AM
Irelands child's Avatar
Why? For what?
Sorry if I/we seem abrupt new guy, but that is not a good question as we are not mind readers on the particular vehicle you are looking at as there were somewhere in the neighborhood of 5000 different makes ever made, worldwide with variations to every brand
Irelands child
Old 01-29-2012, 10:15 AM
S10xGN's Avatar
Gotta love a turbo!
In other words, it's not something important enough that anybody ever bothered to take the time and effort to make a "chart" of. Most guys just have one built from scratch or find one longer and have it cut down.
Russ
Old 01-29-2012, 12:11 PM
Russ
That's the only way to make it fit for sure.
For instance, Ford rear ends. Is it a 1310 or 1330 yoke and oh, by the way, is it a short yoke, long yoke differential or - holy @#$% it's a flange instead - and that trans mission output yoke - C4/C6/FMX/AOD/Cruisomatic - and that's the same thing all over. Now, add in the 7.5", 8",8.8" 9-3/8 plus GM 10 and 12 bolt, etc, etc, etc. Now multiply that by just the different models/engines/transmission combo choices of each brand - and suddenly you have thousands of different possibilities.
The Hollander interchange the salvage dealers use might help, but that's still iffy
Irelands child
Old 01-29-2012, 02:10 PM
Wiki Edits: 85
And don't forget to add in whether it is a golf cart, Terex, short bed, long bed, 2wd, AWD, front shaft, rear shaft, and so on and so forth.
Even the junk yards with the help of Hollander go crazy over shafts.
Old 01-29-2012, 02:22 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A page that might help- http://www.dennysdriveshaft.com/how_to_measure.html
Old 01-29-2012, 04:18 PM
I'm guessing that the O.P. is looking for a reference that allows easy junkyard shopping for a different driveshaft. Unfortunately, such a database would be hugely unmanageable. Here's an example: You would think that there would only be a handful of driveshaft lengths for the 1968-72 GM A-body cars. Unfortunately, the actual number is larger than you think. There were four different wheelbase lengths times two different transmission lengths times at least two different rear axle flange to centerline lengths. That makes 16 different driveshaft lengths just for these relatively common cars over only five model years. Oh, and compound that with the fact that AT cars got rubber isolated driveshafts while MT cars got solid ones.
67 c10 drive shaft bigtank05 Transmission - Rearend 2 09-06-2011 10:17 PM
drive shaft help hotpepper Transmission - Rearend 1 08-21-2007 05:39 PM
Drive shaft???? 66_ford Transmission - Rearend 5 05-12-2007 10:41 PM
Drive shaft JPB Transmission - Rearend 9 01-05-2005 02:27 PM
Drive Shaft street rodder 1937 Transmission - Rearend 3 10-17-2003 03:02 PM
