Drive shaft problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2011, 10:10 AM
chevydragster83's Avatar
Drive shaft problem
I have a 1983 2wd Silverado. Street strip truck (more strip than street). I had a TH-350 transmission with a 9in tail shaft, and I just bought a TCI super street fighter TH-350 with a 6in tail shaft.
My question is What is the best way to go about getting a drive shaft to fit the transmission?
Is there any Chevy truck that came out with a 6in tail shaft transmission that I could find in a salvage yard and just swap drive shafts?
Thanks,
Larry.
Old 03-13-2011, 09:41 AM
Speedway Motors can fix you up with a longer yoke for your drive shaft.
Old 03-15-2011, 08:19 AM
Would the yoke being longer not make it week?
Old 03-15-2011, 03:37 PM
Crosley's Avatar
Wiki Edits: 1659
I've never seen a replacement yoke that was 3 inches longer for the 27 spline trans application.
Have a part number for that?
Old 03-15-2011, 04:42 PM
prostreet6t9's Avatar
Differential/Driveline
Dont think you will find a yoke that long. Might be easier to just have yours retubed longer.
Old 03-15-2011, 07:16 PM
I have a friend that has one that is 59in long and the one I have now is 57. would I be able to find a yoke 1in longer?
Old 03-15-2011, 08:04 PM
One more time here fellows.Speedway has the longer yokes to fix this problem.For a GM 1 3/16 X 27 spline the part # 80292430@$69.99 This is for a yoke that is 8 1/2 inches,They have shorter ones too.
Old 03-15-2011, 08:27 PM
Sure enough! I've never seen one that long and I'm even in that business
So I guess we need to know the length of the OP's original yoke?
Old 03-16-2011, 01:04 PM
well I don't know the size of the yoke thats in it now. I havn't pulled it out yet. I have a drive shaft that is 59 inchs long, which is only one inch shy of what I need. The yoke is just the stock one on the th350 with a 9 inch tail shaft.
I don't know much about that kind of thing. Is there more than one size that came on them?
Old 04-25-2011, 05:51 PM
boatbob2
Speedway YOKES (JOKES)
Hi,i bought the speedway 6 inch yoke last week ,for a 700R4 trans,,it is a PIECE OF S---.the holes for the u-joint caps are .060 undersize. (THATS 60 thousands undersize) unfortunately i cut it down to 5 inches long,, BEFORE trying to insert the caps,a machine shop is charging me $100.00 to turn the holes to the correct size,,,, HEY...SPEEDY BILL,,,SEND ME A CHECK FOR $100.00 ,SO,my $69.95 joke now cost me $169.95. those chinamen sure dont know how to measure ANYTHING....BEWARE OF SPEEDWAY YOKES..
56 drive shaft help 56chev100 Transmission - Rearend 7 07-26-2010 08:49 PM
drive shaft vibration and brake problem fay ellis Hotrodding Basics 6 08-31-2009 01:38 AM
drive shaft help hotpepper Transmission - Rearend 1 08-21-2007 05:39 PM
Tubro 400 tailshaft &drive shaft Problem MAD BOWTIE Transmission - Rearend 11 06-19-2005 11:51 PM
drive shaft problem ecarpener21 Transmission - Rearend 5 06-12-2003 07:09 PM
