Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - drive shaft seems to short after engine swap
Old 11-14-2011, 04:38 AM
123pugsy's Avatar
123pugsy 123pugsy is offline
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Is the back axle hanging or supported on stands?
If its on stands, move the stands and support only the frame of the car.
You can try using a pry bar to just get the u joint into the yoke. Once it gets clear and set into the yoke it will move back about 1/2 - 3/4".
