drive shaft seems to short after engine swap - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-16-2011, 12:12 PM
prostreet6t9's Avatar
Differential/Driveline
Originally Posted by firebird7980
It doesn't matter we're the cross member is the trans is we're it is I Can move the cross member in an spot the trans doesn't move I have the frame mount for the engine in the holes close to the radiators as far as I can tell there is three different drive shaft
Get everything mounted and get the driveshaft adjusted as needed.
  #17 (permalink)
Old 11-16-2011, 08:00 PM
Every thing is all bolt in I need to shorten the drive shaft thanks for the help I guess installing the v8 and differs bell housing push every thing back Enough so it all bolts up in right spot but to fair to get drive shaft in thanks for the help
Drive shaft swap, u-joints???? with pics zbhover Transmission - Rearend 6 08-16-2009 09:16 AM
Drive shaft length for 96 s10 v8 swap eric32 Transmission - Rearend 5 07-07-2009 03:03 PM
9 inch & Drive Shaft Swap Morgan22 Transmission - Rearend 2 06-21-2008 02:30 PM
how short to make drive-shaft Robinson Robin Transmission - Rearend 13 10-19-2003 05:31 PM
is my drive shaft too short? crebo Transmission - Rearend 2 08-19-2002 02:39 PM
