drive shaft slide distance - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2006, 06:42 PM
Is their a general rule of thumb for yoke slide distance?In my case with the car sitting level About an inch of yoke showing between rear trans seal back to yoke at u-joint.It is a turbo 350.
Old 03-29-2006, 07:10 PM
wildman926's Avatar
Never let them see you coming
I just went through the same thing with my son's truck. It was showing 2.5 inches, and it ended up ruining the tailshaft bushing and the yoke on the driveshaft. The guy that made me another driveshaft stated only 1/2-1" showing. So, you should be ok.
Old 03-30-2006, 05:50 AM
Yep I was told by the drive shaft people to push in the yoke all the way and pull out 3/4in. Ed ke6bnl this is regular ride height and all the normal weight on the vehicle. E d
Old 03-30-2006, 06:29 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
An even 1 inch measurement is the standard for street vehicles.
I have seen custom shafts with slip yoke splines up to 24 inches long, but these don't see ANY road time. They'll climb over a 5 foot rock though.
Old 03-30-2006, 04:45 PM
drive shaft yoke distance
thanks guys for the responce on this issue.sounds good to me. I guess i will go with that.
Vibration at speed Doc68 Transmission - Rearend 141 01-22-2005 07:53 PM
U-Joints MI2600 Transmission - Rearend 4 11-14-2004 03:34 PM
drive shaft lenths 37jim Transmission - Rearend 5 12-11-2003 01:04 AM
Drive shaft stuck in tranny? Deadtemple Transmission - Rearend 1 10-18-2003 07:26 PM
Drive Shaft street rodder 1937 Transmission - Rearend 3 10-17-2003 03:02 PM
