drive shaft u joint question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2012, 06:53 PM
75chev4x4's Avatar
Hey guys doing the u joints in my 75k20, got the rear drive shaft out all joints out no problem. The front drive shaft to the front axle the u joints were more stubborn. Finally got them out but noticed that inside where the caps slide into the shaft I got a small groove in both. The cap must have got cocked some on the way out. The. Groove is not really deep but I can catch it with my fingernail. I ran another u joint cap back into the shaftand installed it and it seemed to go in and come out fine. I have limited experience with this and want to know what my options are. Will this cause a problem or should I replace the yokes?
Old 01-15-2012, 07:12 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
it should be ok
Old 01-15-2012, 07:14 PM
75chev4x4's Avatar
Really? Glad to hear you say that. thanks.
Old 01-15-2012, 07:31 PM
& matts38chev
as long as the cap doesnt turn in the yoke (because then the bearings are not rolling) it should be fine
you can draw a line across the end of the cap on to the yoke to check it later and see if its spinning in the yoke
you could also use a small amount of some light duty lock tight on it
Old 01-15-2012, 07:42 PM
75chev4x4's Avatar
Ok I will do that, thank you sir!
Old 01-16-2012, 09:20 AM
75chev4x4's Avatar
One more question if I can about the rear drive shaft. It bolts to the rear end and to the back of the tcase and slips together in the middle. Problem is that I wanted to get all the old grease out of the part that slides together in the middle so I pulled it apart to clean it and it came apart before I remembered to mark the shaft. I put it back together with the ends lined up parallel hoping this is correct. I did notice it has some washer looking tabs welded on both ends on opposite sides for balancing I believe. Since the balance tabs are on opposite sides I think I have it right. Any suggestions.
Old 01-16-2012, 05:05 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
As long as you have them lined up like in the pic below then your fine.
Cole
Old 01-16-2012, 11:49 PM
75chev4x4's Avatar
Cool, thank you!
Question about drive shaft iceburgh Transmission - Rearend 3 01-05-2006 08:34 PM
3 joint drive shaft 59 348 Transmission - Rearend 14 11-02-2004 07:45 PM
Closed Drive shaft question Jackyl Transmission - Rearend 3 06-05-2003 03:24 PM
St-10/ 2 piece drive shaft question 85406 Transmission - Rearend 1 04-16-2003 01:36 PM
