Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Drive Shaft Yoke
Old 04-03-2010, 06:41 PM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Differential/Driveline
Originally Posted by frickenbored
I have a drive shaft with a slip yoke on my 88 K5 blazer and today I was changing the u-joint when I noticed that one of the ears is cracked...so now I have to replace this slip yoke, problem is I can't find one anywhere. Maybe some one has seem them somewhere...on one side of the yoke it says: SPICER Z28 on the other side it says: F3-3-29 H SCAN. Its 16 spline.
Don't weld it! Since you said its 16 spline I'm assuming its the slip yoke that slides on the stub of the driveline. Google Spicer 2-4-8001KX. Thats for a 1310 U-joint. The longer version of that yoke is Spicer# 2-4-8021KX.
If you dont have the 1310 series U-joint, give me the measurements of the joint and I can tell you the part number for the yoke.
