Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Drive Shaft Yoke
Old 04-04-2010, 09:43 AM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Differential/Driveline
Originally Posted by frickenbored
well heres the thing, this driveshaft is temporary. I only need it to work untill I get my 14 bolt full floater in with a 4" lift. Then I'm going to get a custom alu driveshaft with a 1330 u-joint at the front and a 1350 u-joint in the rear and convert my np203 output yoke from a 1310 to a 1330, plus this driveshaft will likely be to short anyway. The driveshaft I have now looks like it was hacked up a couple times, I just need this yoke to hold for a little while so I can move the truck to work on it, its not a daily driver. I don't really want to pay $50-$100 on a yoke that will be useless in less than a year.
You should be able to find one for $40 to 45ish. If that's still out of your budget maybe you should look in the junk yards. Its just not a good idea to try and weld up cracks in the yokes. If that comes apart you might end up spending way more than $50 bucks fixing the damage it caused.
