5100 upshift sounds good for hard acceleration in 1st. depending on your manifold rev range- you may actually start dropping off power and torque by the time you reach 5100 anyway, i.e. manifolds are designed to operate in a rev range.
Thanks, 5100 sounded ok to me also. I do need to open the exhaust up a little. Been thinking about some Corvett rams horn manifolds, my engine builder said there good for 30 hp.
My s10 (with 2.8L and 700r4) has the factory shift point at 5750rpm. If your motor is good till 5200 then a 5100 shift point sounds fine to me. I wouldn't set the rev limiter to 5200 though. It might kick in every once and a while and cause the trans to never shift. I would set the rev limiter to something more like 5500 (assuming your engine can handle that). My rev limiter is set to 6250 because with it set at 6000 it would sometimes hit it and not let the trans shift.
| Erson Gear Drive Woes | blndweasel | Engine | 9 | 07-14-2004 09:53 AM |
| '87 tpi to carb | newcustom | Engine | 11 | 07-02-2004 06:26 PM |
| 350/350 not getting out of drive | MRGM | Transmission - Rearend | 11 | 04-28-2004 10:48 AM |
| Boost 700R4 | ChevyVan | Transmission - Rearend | 2 | 01-12-2004 02:51 PM |
| 700R4 vs. 2004R | 81ElCaminoGuy | Transmission - Rearend | 2 | 08-21-2002 01:10 AM |
