Drive to the Upholstery Shop
Well, it finally stoped raining long enough for me to get my PU to the trim shop. I have been solving oil pressure problems (new sending unit fell on its face), got the 2 1/2 inch exhaust pipe on to replace the 2 inch butcher job. The first Yaahoo not only screwd up the exhaust system, he cross threaded the new O2 sensor at the tune of $59. But did the extra half inch bring the motor to life!! Every young guy should get to drive a choked down motor and then try it when it is opened up to breathe!! The truck drove like a dream and the motor purred like a lion and I never obtained more than 1/3rd throttle. The EFI will be tuned a bunch on the return trip. Right now, it does not like 2100 RPM and moderate load in 4th gear overdrive!! 39 degrees total timing is a little much with 10.2-1 compression.
Trees |
Have a few in the new Cam, Just got to get them down loaded. I'm trying to load up some oldies for the Senior Citizens of the board: should be up in the next few minutes
Trees |
Coleman, I have the 2.5" dumps and they were choked down. I also have the same setup on a 327 as you in a 36 Ford coupe. It has the Vette heads, a GM competition dual plane high rise, and the Crane regrind of the 300HP Vette cam but is improved because of the dual pattern. I have the PU 2" Rams horn exhaust because of clearance problems. It runs fine, but 2 1/2" would improve it. Scoggins Dickey, a GM Competition Parts dealer sells new 2 1/2" rams horn Corvette manifolds and are very reasonable (scogginsdickey.com). You can go the Cast Sanderson Headers which are better but EXPENSIVE. I will put these on my 327 down the road because they are much tighter fitting.
Trees |
| Recent Hotrodders' Lounge posts with photos |
