Drive by wire - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2005, 04:03 PM
Angry Drive by wire
Hi All: I have a '61 corvair pu. The throttle sucks,is to stiff or won't let eng idle.How would I install a drive by wire system? Thanks in advance.Justin. Yes I put a new cable on it
Old 02-04-2005, 04:43 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Welcome. Being new to the site, you need to be sure to read the "Read Me' posts at the beginning of each forum. The ones here for example recommend that you just post a general introduction here and post tech questions in the appropriate tech forum. This will give you the best chance for a good answer.
Old 02-04-2005, 05:54 PM
poncho62's Avatar
Wiki Edits: 5
Moving to engine forum............
Old 02-04-2005, 09:21 PM
4 Jaw Chuck's Avatar
Try a hydraulic throttle from Jegs.
— Han Solo
Old 02-05-2005, 07:50 AM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
Drive by wire is a term used for cars that have no mechanical linkage. The C5 Vette was one of the first production cars to run this set up. You will need an ECM controlled engine. The engine is controlled as far as RPM by a throttle positioning sensor under the throttle pedal itself,and sends a message to the ECM. The ECM than sends that signal to the fuel injection,spark system,etc.
Old 02-05-2005, 08:59 AM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
I have seen servos for remote control cars that could work, but it best be right!
Uh, i'm sorry ociffer, i was 90 in a 30 b/c i drive by remote control!
Old 02-05-2005, 11:39 AM
cboy's Avatar
Last journal entry: Finished
Is it actually binding at somewhere in the linkage/cable or is it binding at the carb itself? Have you been able to identify exactly where along the line the thing is hanging up?
Always learning...and sharing what I've learned.
Old 02-05-2005, 12:45 PM
rick458's Avatar
Wookie
It would seem to me, to be Much easier to replace the gas pedal assembly, and run the new cable with fewer angles, than try to electrically drive a non EFI engine.
Rich
77 Impala
74 260Z (a Work in SLOW Progress)
69 Big Block Chevelle (long gone)
Semper Fi My Brothers
Old 02-05-2005, 02:26 PM
Drive by wire
Thanks 4 the replys. Gentlemen. There seems 2 b a lot of misunderstanding about drive by wire. ECMS,Tbi,etc r not neccessary 4 this.All that is required is accel pedal with a potentiometer and a servo motor to operate any type of movement being carb, tbi, anything you want to be remote operated. Justin. Master tech Cert 35yrs my own shop. I don't know the parts to use.Thanks again
Old 02-05-2005, 04:04 PM
NXS's Avatar
NXS NXS is offline
Yes, i'm sure with some trial and error a TPS off a junk tbi and the right servo it can be done. just make sure all is 100% correct!
Old 02-05-2005, 07:45 PM
The problem with an electric throttle control is that there is always a load on the servo because of the return spring pressure. The only reason why manufacturers use them is to interface the computer inbetween the human and the engine to overide the human when necessary.
What is wrong with hydraulic? There are many manufacturers of these type of throttle controls on the market? I once used one to syncronize two 350HP diesel electric gensets on an old locomotive, worked like a charm and was the only inexpensive way to actuate two throttles simultanously. Sure beats tuning two cables to get the same effect.
Mico hydraulic throttle control systems PDF.
If you must have an electric then try Williams Controls. They are the leader in offroad electronic throttle control systems.
— Han Solo
