Drive by wire - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2006, 02:40 PM
Animal's Avatar
Dominators Hot Rod Club
Last journal entry: On the run
Drive by wire
This could be an engine question also.
I'm building a rod from scratch with the engine in the back. Running an accelerator cable around to the back and around and over the motor is cumbersome and may be prone to sticking.
Has anyone set up a drive by wire, using a servo to work the carburetor?
Animal
Old 02-04-2006, 03:01 PM
Wiki Edits: 49
Check with your local Dodge dealer. I'm not sure about all the Dodge trucks but I do know the Hemis use a "drive by wire" setup on their throttle.
Old 02-04-2006, 03:34 PM
302 Z28's Avatar
Just about all the new cars use it. Our 04 Tahoe has it, no throttle cable at all. You would however need the computer that runs everything else on the car to make it work though.
Vince
Old 02-04-2006, 03:42 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
The Fiero has the engine in the back and I have had 5 of them and never had a problem with a long cable.
My latest one is powered by a SBC with a carb setup.
Old 02-04-2006, 04:23 PM
Animal's Avatar
Drive by wire
I am running with a carb to avoid a computer. I've seen cars driven by remote control, including throttle, on Myth Busters and Monster Garage.
Then there are all those RC toys running around.
Old 02-04-2006, 05:04 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Too complicated. Too specialized. Safety issues. Engineering issues. No kits available. Not adaptable.
Don't forget KISS.
Try this.
Hydraulic clutch set-up adapted to throttle control.
Just a little fabrication and ................spank-the-street
vicrod
Old 02-04-2006, 05:13 PM
Wiki Edits: 31
what about using a single master cylinder hooked to a small brake line ( 3/16" ) that goes to a small hydraulic ram cylinder of some sort, that is bolted to carb linkage, hydraulic force, run the lines under the car, the pedal won't stiffen up if you get the linkage the right length, but even if it did, by that point you'v got it & WOT anyway. you could probably modify a wheel cylinder by closing off 1 side somehow.
Old 02-04-2006, 05:29 PM
Animal's Avatar
Drive by wire
Great ideas all.
The KISS rule is always first choice. But I'm concerned about the lenght of cable and the number of sharp turns, especially out through the firewall where the cable will have to turn a 90 in about 1 1/2 inches.
The hydraulic option is possible, but will it respond quick enough, especially when getting out of it?
Animal
Old 02-04-2006, 05:36 PM
Wiki Edits: 31
Originally Posted by Animal
Great ideas all.
Animal
you might need to fiddle with return spring tensions but it should go back just as quick as a cable.
Old 02-04-2006, 05:37 PM
vicrod's Avatar
life is a ride
Hydraulic is a mechanical connection.
If you used plastic tubing you might get a little "inflation lag".
Go with 3/16" copper tubing.
vicrod
Old 02-04-2006, 05:44 PM
steve t's Avatar
ex biker, now hotrodder
all go karts have motor in back, an top fuel cars
Old 02-04-2006, 06:49 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
If Cost is NOT an Issue, Litton Microwave made Auto Throttle (servo activated throttles) Systems for the Boeing 757/67 projects, for total automated ILS landing systems..The FAA bounced it..Didn't like the idea of a robot landing a jumbo jet..
Anyway these may be out there somewhere surplus , I'm for sure Litton Does not make them anymore..If you do find one, even surplus..expect prices to start at the high 4 digit $$ range and go up from there...
Have you Considered the possibility of a VW or Porsche throttle system? Something you could run under the car to the rear? If you have enough Cable length, It may work..
You didn't say what kind of car this was, is it to be a street driver, Strip?
Years ago ( about 35, to be exact ) The rear engine Dragsters used to use an "In and Out " hydro..
When you dropped the trans into gear, it went to WOT until you went back to neutral..
The NHRA outlawed it back then, when a Funny Car went WOT into the stands while attempting to enter the Staging line at Fremont Raceway.
Low budget, low tech, safe approach would be to adapt a rear engine car throttle system to your application..Maybe even look into what big trucks (semi's ) are using..
Doc
Old 02-04-2006, 09:33 PM
Years ago we had a rear engine dragster with an Eelco Hydraulic throttle on it, it never was a problem.
Old 02-05-2006, 01:05 AM
Da Hellion's Avatar
cable
I agree with the kISS concept I think a cable would be fine if routed correctly avoid sharp bends and make sure where the cable hooks to the carb it's nice and level.Put extra brackets to hold the cable housing still .Keep tweaking it until it is smooth as possible. The most important thing is the return spring . With the longer cable you will probley need a heavier spring but if it's to strong it will be jumpy as you first accelerate
Old 02-05-2006, 02:12 AM
allthough the suggestion or reference to rc models was made you will find that none of these types of servos will have the pulldown strength you need to over come a carb and returns and what not now a hyd throttle has been mentioned several times i would suggest you search neal brakes on the net they have an perfect working hyd throttle set up i have been running this in my rear engined street legal sandrail for many years with no problems the cable method is still the best my daughters rear engined sandrail uses a 15' long teflon lined cable from a company called cablecraft thing works smooth as silk
regards 2088bob
new welding wire oldred Body - Exterior 93 05-07-2009 04:40 PM
1 wire alternators.... Crazy Mopar Guy Electrical 36 04-09-2006 06:37 PM
1986 Cutlass wiring Q's again :( ChrisMiddleron Electrical 12 07-16-2005 04:22 PM
one wire / three wire, alternator hookup 65truck Electrical 1 10-24-2003 03:59 AM
85 s-10 distributor wiring question strracer7 Electrical 1 09-29-2003 03:39 AM
