Driveability question on Camaro Clip - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2010, 12:05 PM
garretthes's Avatar
Last journal entry: Rear Axle swap #2 (74 Camaro) part 6
59 Suburban with 74 camaro subframe.
Just had it aligned. Everything is to factory spec except the castor. Factory recommends -1 to +1
Actual adjustment -4
Is this 3 going to make a huge difference?
Thanks, Garrett
Old 04-26-2010, 02:59 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Yes, negative 4 degrees caster will make the steering very very twitchy at highway speeds. It needs to be corrected to at least 1 degree positive, I usually run 2 1/2 to 3 degrees positive caster on a front end such as yours. Set the camber to 1/2 degree negative. Don't bother with the factory specs.
Finish with 1/8" toe-in and you will be on the right track.
Andy
Old 04-27-2010, 09:59 AM
garretthes's Avatar
It definitely drives better after the alignment. It is still twitchy above 70 though. I'm looking at replacing the upper control arms to correct the castor problem
Old 04-27-2010, 10:57 AM
The more positive you can go on caster, the more stable at high speeds. Negative can not only be twitchy, it can lead to shimmy. 3-4 degrees is a good ballpark for power steering. 4 degrees with manual steering can start to get tiring in a lot parking lot maneuvers. If you even remotely like driving it at -3, you'll fall in love at +3. Keep both sides close with a .5 degree split with the lower number on the side of the road crown. The front end will drift to the lower number and that drift is just right with a normally crowned road to not pull in either direction.
Old 04-27-2010, 08:32 PM
garretthes's Avatar
You guys rock
3.4 camaro SFI fuel line question dusterbd Engine 1 03-30-2010 09:50 AM
Different kind of clip Question. 1982 camaro purespl Suspension - Brakes - Steering 7 11-23-2009 11:13 AM
Chevrolet PU 51' with Camaro Clip very low !! Getting higher ?? achimpfeffer Suspension - Brakes - Steering 8 03-28-2008 08:09 PM
another camaro question notmrgoodwrench Engine 6 01-03-2004 02:07 PM
Just scored a Split bumper front clip for my Camaro Camarofiend73 Hotrodders' Lounge 2 12-15-2003 02:38 PM
