Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - driveline angle issues....
Old 07-01-2006, 01:57 PM
joe350s10's Avatar
joe350s10 joe350s10 is offline
Bigger is better
I recently discovered...much to my shagrin...that i have twisted the driveshaft in my truck 8 degrees off center.
Of course, I will be buying a new driveshaft soon...but I have a quick question...
Due to the fact that I shoehorned the V8 into my s10, I don't have alot of adjustment when it comes to the tranny to rear end angle.
the tranny is angled up as far as it can be but it is still no where near the same angle as the rear end.
It has been suggested to me that I could either add wedges to the rearend mounts to turn the nose up to the correct angle or cut the mounts off and reweld them in the correct position.
So, has anyone else had this problem?
How did you choose to fix it?
