driveline angle issues.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2006, 02:57 PM
joe350s10's Avatar
Bigger is better
I recently discovered...much to my shagrin...that i have twisted the driveshaft in my truck 8 degrees off center.
Of course, I will be buying a new driveshaft soon...but I have a quick question...
Due to the fact that I shoehorned the V8 into my s10, I don't have alot of adjustment when it comes to the tranny to rear end angle.
the tranny is angled up as far as it can be but it is still no where near the same angle as the rear end.
It has been suggested to me that I could either add wedges to the rearend mounts to turn the nose up to the correct angle or cut the mounts off and reweld them in the correct position.
So, has anyone else had this problem?
How did you choose to fix it?
Old 07-01-2006, 04:13 PM
powerrodsmike's Avatar
Wiki Edits: 161
you can get 2*(and I think 4*) shims from any speedshop, 4 WD shop or mailorder catalog. If your pinion angle is out of alignment with your trans output shaft by more than 4* I would redo the spring perches.
Here is a link to the section in the KB with several articles that explain why proper phasing and angle is important.http://www.hotrodders.com/kb/browsel...atid=55&page=2
Hope this helps,
mikey
BE different....ACT normal.
Old 07-03-2006, 11:47 AM
gdubstub's Avatar
Old Crusty Streetrodder
Another good site is www.iedls.com, Inland Empire Driveline Service. They have a great tech section that explains all the geometry you need to employ in a driveline setup.
George
Old 07-03-2006, 08:57 PM
carnuck's Avatar
I do 4x4 stuff and the way we cure these issues is with a fixed yoke trans output and a driveshaft with CV joint at the front, and tipping the differential so it is pointing directly at the trans.
Check out Tom Woods for high angle shafts.
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 39 03-29-2015 10:02 PM
1986 or somewhere around there s10 driveshaft angle problems fumplet Transmission - Rearend 10 01-16-2006 10:20 PM
notching tubing benchracer1 General Rodding Tech 16 04-13-2005 12:02 AM
short driveshaft high angle ujoints powerrodsmike Suspension - Brakes - Steering 16 02-09-2005 08:58 AM
Offset pinion and driveline angle? I nned advice. mike bryan Transmission - Rearend 4 10-25-2004 07:37 AM
