Driveline Angles on V-8 Vega - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2008, 05:33 PM
Greetings
I get a vibration on deceleration only,under power it's smooth.
The car is a street/strip 75 Vega with a 383,turbo 350,12 bolt 4-link rear with adjustable upper & lower control arms.
The trans is at 2 degrees down,the pinion at 3 degrees up,the driveshaft is sitting at 5 degrees and it's 41'' long.In this configuration it's ran 11.76@113
Are the working angles of the driveshaft O.K.? Am I missing something?
Hoonbash
Name:	Damn Near Done 001 (Small).jpg
Old 10-10-2008, 11:10 AM
SSedan64's Avatar
Pinion Angles
Here's some Info on Pinion Angles.
http://www.buickperformance.com/Pinion.htm
http://www.2quicknovas.com/happypinions.html
http://www.wolferacecraft.com/pinionangle.aspx
Old 10-10-2008, 05:39 PM
Thanks for the links, I think the Wolferacecraft site has the answer for me.
Pinion Angle Recommendations:
Suspension Recommended Angle
Using Full Wolfe Race Craft Suspension - all solid mounting points. -1 to -1.5
Half Solid & Half Poly Mounting points -1.5- to -2.5
All Poly mounting points -2.5 to -3.5
All Rubber mounting points -3 to -4.5
The more you get away from having all solid mounting points the more the rearend is going to try and rotate upward during launch. Therefore the more angle you must start with to prevent the angle from becoming positive (+). The idea is that when the rearend rotates you want the angle between the driveshaft and the pinion would be 0.
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 39 03-29-2015 09:02 PM
Old question....new problem....driveline angles? Stovebolter Transmission - Rearend 5 08-27-2008 03:42 PM
Driveline Calculators Stovebolter Transmission - Rearend 1 04-13-2008 08:24 PM
how to determine correct pinion angle upthcreek Transmission - Rearend 2 12-22-2005 07:58 AM
driveshaft angles, what about horizontal angles catscan4free Transmission - Rearend 4 01-26-2004 06:23 PM
