Depends on the convertor. You can get any convertor with an anti-balloon plate added. I know alot more about engine than trans, so I would call some trans people and ask.
I have watched flexplates while a car was being dyno tested and the flex in the ring gear was noticeable and the amount of deflection surprisingly large. |
Check the TC/TorqueConverter snout to see if it's been contacting the Flexplate in the center.
TH400 Trans are bad about balooning TCs. The TC feed circuit can be restricted to prevent this. Good Info in this Thread about Orifice sizes etc.. >> http://www.turbobuick.com/forums/tra...-pictures.html Crappy Off Shore Cranks can also be a cause of wiped out Thrust surfaces. |
High trans line pressure and/or clogged or restricted lines or cooler can also contribute to wiped thrust bearings according to some.
| Need a driveline. | junior stocker | Transmission - Rearend | 0 | 07-26-2009 08:22 AM |
| Hyd. Roller Lifter Check.....Check | greenmoonshine | Engine | 11 | 07-22-2009 12:25 PM |
| wiki: How to check driveline angle | Jon | Transmission - Rearend | 5 | 04-18-2008 11:54 AM |
| driveline | Jerry Sawyer | Transmission - Rearend | 2 | 01-31-2007 05:52 PM |
| driveline | 3dhunt | Transmission - Rearend | 1 | 03-24-2004 05:15 PM |
