Driveline question!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2004, 05:57 PM
I'm getting ready to mate my rear end to my 700R4 trans and I was told yrs ago that my rear end should be 2 degrees pointing upward, is this correct? Or better yet is their a sight that shows a nice diagram or something on the proper specs to mate each one? Thanks Dana
Old 03-03-2004, 06:12 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
if you're talking about pinion angle, i think if you do a search in the Hotrodder's knowledge base there will be info in there.
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 03-03-2004, 07:55 PM
thanks JB, I will give it a shot!
Old 03-05-2004, 01:00 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I have an Alston back-half installed with the FAB-9, their direction is to have the pinion at 1 to 3 degrees down. That's with a 4-link. As it turns out that's where I needed it to maintain a relatively straight shot to my tailshaft.
Good Luck
Old 03-05-2004, 04:50 PM
Wiki Edits: 49
Check out Inland Empire Driveline. Everything you need to know is there.
Centerline
Old 03-06-2004, 06:20 PM
thanks again, great site, Dana
