Driveline vibration? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2006, 07:11 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
Just got the Anglia back from the trans guy (New 700r4)...
It has a weird vibration, almost like a tire out of round from sitting too long,but more subtle.
When I drive 35ph 1700 rpm...I get a vibration one every second and a half...If I get it up to 45 2150 rpm it happens about every half second.
Above 2200 rpm I can't detect it..I didn't have this problem prior to the new trans, or if I did it wasn't as noticeable.
The u-joints have 1200 miles on them and the drive shaft was balanced 1200 miles ago.
Any ideas...
355,700r4,Ford 9 w/389s
Old 12-05-2006, 07:17 PM
Driveline vibration ?
Do you have the vibration sitting still,in park,engine running at same RPM's?
Old 12-05-2006, 07:21 PM
AngliaBob's Avatar
Briscoe,
I will go out and check it now...
Do you have an idea this is not driveline related?
Bob
Just checked it out in Park...
I do have the vibration, but is much more subtle...
Old 12-05-2006, 07:45 PM
Bob,was the torque converter replaced with this rebuild?
Balance problems are rare with converters these days,but do occur.
The fact that it does vibrate sitting still may point to converter.
You may be able to disconnect [unbolt] converter from flexplate,start engine,then see if vibration goes away. Use caution,[clearance]don't let converter get loose and contact flexplate.
Years ago we used a converter company,best not state their name,had many vibration concerns,sometimes just unbolting converter and rotating to another spot on flexplate would make vibration go away. Dana
Old 12-05-2006, 08:09 PM
AngliaBob's Avatar
Dan,
Yes it is a new converter...
New Trans and converter ... from Bow Tie Overdrives...
Will try unbolting converter and see if vibration goes away...
Maybe on Saturday...
Will post my findings...
Thanks again,
Bob
Driveline Vibration caused by Harmonic Balancer!! 71gtx Engine 1 06-03-2005 01:09 PM
Troubleshooting Driveline Vibration PrimaDude Transmission - Rearend 9 07-01-2003 11:57 AM
Driveline Vibration Problem PrimaDude Transmission - Rearend 2 06-01-2003 03:43 PM
Driveline vibration '31Vette Transmission - Rearend 6 05-06-2003 05:03 PM
strange driveline vibration? jpm Transmission - Rearend 9 12-14-2002 08:25 PM
