Driveline Vibration caused by Harmonic Balancer!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2005, 11:41 AM
Last journal entry: Rear End Disassembly
Welll I've been trying to solve this problem foreeeeever. I have a driveline vibration on my 71 plymouth and I kept searching under the car from the trans back. I finally did notice though that my harmonic balancer, vibration damper, and everything else in that cluster shake horribly at idle. When throttle is applied they seem to go away but nonetheless I think that could relate to my problem. Anyone agree???
If so, the next qustion I have is can evertyhing be tightened or do I need to replace anything?
Old 06-03-2005, 12:09 PM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
Not very familar with MOPAR,but if the balancer has that elastomer crap like the General uses,it needs to be replaced with new.It can also cause damage to your crank if it is that far out of balance.
283 Harmonic Balancer JamesD Engine 29 03-14-2007 05:36 PM
bad harmonic balancer? smlblcks10 Engine 5 01-31-2005 11:21 PM
Harmonic Balancer Failure Vista Cruiser Engine 10 11-23-2004 03:04 PM
engine vibration / harmonic balancer briansansone Engine 4 11-01-2004 09:29 PM
Harmonic Balancer Installation DTL504 Engine 2 06-15-2004 10:17 AM
