Driveline w/ angle pig question? How to fix - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2008, 09:06 AM
I have lowering blocks, (only 1/2 of one used to get my angle right, I thought) But when I started it up and try to put it in gear sounded funny. Tried reverse, neutral drive etc. really didn't go in real good (automatic Lokar) shut it off and I looked , my yoke came out of course because My perches angles back about 45 degrees ointurn pulled yoke ot that much and it sheared off my lowering block knob to go into my perch. I am thinking I have the wrong angle but how can I fix this the easiest way? I do have shackles. Advise big time! Thanks, Dana
Old 07-13-2008, 10:17 AM
Originally Posted by 39chevy
my yoke came out
If the yoke came out of the transmission ... you had a too short driveshaft IMHO. I always push the yoke all the way in and then pull it out about 3/4" to one inch. Thats where the yoke should run with the proper length driveshaft.
You can purchase angled shims ... to correct the angle on the pinion.
Summit sells them ... if you do not have a local speed shop.
Hotrodders Guidelines -- READ ME Jon Body - Exterior 0 06-14-2003 05:00 PM
Hotrodders Guidelines -- READ ME Jon Interior 0 06-14-2003 04:59 PM
Hotrodders Guidelines -- READ ME Jon Transmission - Rearend 0 06-14-2003 04:58 PM
Hotrodders Guidelines -- READ ME Jon General Rodding Tech 0 06-14-2003 04:57 PM
Hotrodders Guidelines -- READ ME Jon Engine 0 06-14-2003 04:53 PM
