Driven, drive gear info - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2004, 02:18 AM
Can anyone tell me the different gears I will need (driven / drive) for the speedo on a TH350 from 84 that came with a 231(as I understand it they installed different drive gears from the factory in different 350s) if I'm going from the stock 2.41:1 to 3.23:1 gears? How many teeth for each? I havent even looked to see how many teeth is on the driven gear yet, thanks.
Old 07-26-2004, 08:43 AM
Last journal entry: PICTURE TEST
gears
I can if you give me the rear tire diameter.
Keith
Old 07-26-2004, 03:14 PM
Oh yeah, duh, 25.85"
Old 07-26-2004, 07:25 PM
STILL need the driver gear number.....
There are 8 different drive gears
7
8
9
10
17
18
19
20
and 17 driven sets
18,19,20,21 and 22
34,35,36,37,38,39,40,41,42,43,44 and 45
You can tell what the number is by the color of the gear.
Formula for speedo correction.
The speedometer cable must turn 1000 Revs in 1 mile.
tire height 25.85 X 3.1417 (pie) =81.21
A mile is 5280 Feet so X 12" is 63360 inches
63360" divided by 81.21" =780.2
Your tire turn 780.2 times in a mile
Your gear ratio is 3.23 so 780.2 X 3.23 = 2520
Your driveshaft turns 2520 times in a mile.
The cable needs to turn 1000 times so......... 2520 divided by 1000 is 2.52
The ratio between the driver/driven must be 2.52
EXAMPLE............if you driver gear is 8
8T X 2.52 = 20.16 or a 20T driven and you will be corrrect
DEUCE General Rodding Tech Moderator.........
Old 07-27-2004, 02:01 AM
Take your tire diameter & gear ratio to www.novasource.org/speedo.htm & plug it into the formula in the text to get the speedo gear ratio needed, then look at the charts to see what combination comes closest to what you need.
You can work the chart backwards to see what drive gear you have by counting the teeth on your old driven gear.
There are rev/mile & tire diameter calculators at http://tciauto.com/tech_info/speedo_gears.htm
Old 07-27-2004, 08:11 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Some of the gear counts listed by Deuce are for a BOP tail housing. They do not directly interchange with a chevy style speed-O.
The drive gears ..... 17 teeth on up or for a Buick / Olds style. The diameters are different .
Same for the driven gears 34 teeth & up
