Driveplate replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2007, 08:42 PM
I have a '83 Chevy C10 that just died due to what I assumed was transmission problems. However, upon further investigation I noticed that the driveplate cracked and sheared off the back of the crank. My question is assuming I can get the bolts that held it on off the back of the crank, can I just replace the driveplate with a new one, or does it have to be balanced with the crank and balancer?
Old 10-16-2007, 08:46 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
do you mean flywheel/flexplate, if so they are balanced by themselves and are bolt on
Old 10-16-2007, 09:31 PM
should just be a bolt on deal just get the correct # of teeth and make sure you get the 2 piece main one ....bolt pattern changed for 1 piece main
Shane
replacement pickup truck - your advice please jojo99 Engine 3 04-28-2006 04:48 PM
replacement pickup truck - your advice please jojo99 General Rodding Tech 6 04-28-2006 01:18 PM
metalshaping and panel replacement '40 Willys roof Randy Ferguson Body - Exterior 18 11-26-2005 09:00 PM
Replacement for displacement is $ in my pocket. kane583 Hotrodding Basics 15 03-15-2005 06:01 PM
'66 Mustang Master Cylinder Replacement RAW Suspension - Brakes - Steering 2 03-03-2003 09:12 AM
