Driver door adjusting - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2013, 01:52 PM
On my 1939 chev 2-door sedan,on the driver door. The bottom rear section of the door needs to go in-and the top rear section needs to come out more.The front part of the door seems to fit fine. Has anyone had to do adjustment on the door like this? I have factory door hinges.
Old 08-01-2013, 02:16 PM
Faith - Respect - Trust
What type of work have you done to the frame or body? Without physically seeing the vehicle it's a little difficult to give you a "just do this" answer. How much does the bottom need to go in and how much does the top need to come out?
Most times doors are slightly inwards (very slightly) at the front of the cabin, this is done so that rocks don't hit the outer edge of the door while driving...I don't know if this will help because i don't know how far out the door is.
If you could give a little more information or pictures would help.
Ray
1940 pontiac--Adjusting door hinges David N. Aker Body - Exterior 2 11-20-2011 12:34 PM
adjusting the door on a 1993 jeep cherokee gator412 Body - Exterior 10 06-25-2009 10:14 AM
1967 nova A post for driver,s door oldschool427 Body - Exterior 0 08-21-2007 01:42 PM
Driver Side Door Alignment for 01 f-150 satexasf150 Body - Exterior 1 02-02-2007 08:07 PM
Help req'd adjusting door hinges (binding) Ripped Body - Exterior 5 11-10-2006 12:23 AM
