driver window 40 ford pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2002, 08:55 AM
Post driver window 40 ford pickup
Have drivers side window fell out of track and dropped in door and now is cracked. Need to replace and cant figure how to replace or remove. Door is solid except for apprx. 10x10 opening in center of door panel. Can anyone explain how to remove and replace ? Thanks!!! Ron
Old 01-07-2003, 08:38 AM
Post
I'm sure you've solved this problem by now. The window goes out through the slot it rises up and down in.
