Which Driveshaft? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2008, 09:28 PM
need strog32 chevy front doors
Last journal entry: Tbd
Which Driveshaft?
Complete newb to working on driveshafts.
I going to need one soon. What components does the driveshaft consist of.
I have a chevy camaro T-5 That i will go figure out the spleen count. I need a driveshaft that will connected that to a sonoma gmc 1998 rear end.
all gm right. is there a factory shaft that may need to be cut to length but is compatable.
from reading i understand there are 3 u joint types. what are they which should i chose.
one piece setup or two??
any picds to help me understand
Old 08-02-2008, 10:09 PM
SSedan64's Avatar
Not sure I understand. Do you intend to install the T-5 into the 98 Sonoma or other? Sonoma's came with 5-speeds so you may find what you need in the Junkyard.
Old 08-02-2008, 10:24 PM
sorry its my rear end thats sonoma 98. its a 32 chassis. spleen count is 27 or so on the output of the tranny. i can go to the salvae yard but i have no idea of what i should be looking for
Old 08-13-2008, 01:46 AM
anyone know what will be a bolt in if you neglect the length factor
Old 08-13-2008, 09:12 PM
SSedan64's Avatar
Do a search on this site or ask the question here. I'm sure these guys will know.
http://www.nastyz28.com/forum/forumdisplay.php?f=19
Old 08-13-2008, 09:49 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
If there is a one piece Sonoma drive shaft , that should bolt up to the differential and slide into the 27 spline out put shaft of the transmission.
Probably many of the S-10 drive shafts would fit each end. Shorten to needed length
700 r4 to 8.8 driveshaft murrsue Transmission - Rearend 12 10-23-2006 11:36 PM
How long is your driveshaft? MotorCityCarMan Transmission - Rearend 1 06-23-2006 06:30 AM
Multi-section driveshaft ckucia Transmission - Rearend 23 05-07-2006 12:01 PM
1986 or somewhere around there s10 driveshaft angle problems fumplet Transmission - Rearend 10 01-16-2006 09:20 PM
Driveshaft measurement 71gtx Transmission - Rearend 6 01-11-2004 11:00 AM
