Driveshaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2012, 09:24 PM
Driveshaft
Looking for a little help. I have a 64 Chevy Impala replaced the small block with a big block and switched out the 2 spd powerglide for a 700r4 transmission, now i am having an issue with the length of the driveshaft dont know wether to have one built(cost?), have the stock cut and balanced? Also do not know where to go to start looking. I found a company that has one for my application but its $700 and don't know if thats too high. thanks for any advice!
Old 10-16-2012, 10:37 PM
prostreet6t9's Avatar
Differential/Driveline
If you can have yours shortened and balanced.... just do it that way. 700 for a shaft is pretty high.
If your tube and your ends yokes are in good shape it will work just fine.
Old 10-17-2012, 05:14 AM
SSedan64's Avatar
Yikes $700 is about double what it should cost.
In Fl. >> Precision Shaft Technologies, Carbon Fiber Driveshafts and Racing Shafts
Dennys Driveshaft and driveline parts High Speed High RPM Balanced Steel and Aluminum Drive Shaft Specialist
Driveline Parts: SFI Foundation, Driveshaft, Yoke, Universal Joint, Custom Driveshaft
Old 10-17-2012, 05:29 AM
Last journal entry: was hoping for better than this
I had a new one build for my SS and it was 325.oo
and I stepped up to a 3" thick wall tube..
they used my yoke..
goning to a bbc I'd have a new tube as any rust will make it weaker..
any truck repair shop should know where the local driveshaft builder is..
I'd bring them your part and tell them what you got, and how hard you'll drive it..
after they look ovr the tube, they may say yours is fine, or advise you replace it..
Old 10-17-2012, 07:04 AM
Irelands child's Avatar
Any shot that does truck machine work will be able to 'fix' yours to fit. Before I went with a Denny's for my car, had one built using my yokes. $125 including new u-joints
Old 10-17-2012, 05:09 PM
Inland Empire is the one who wants $700. Denny's doesn't make 2 piece driveshaft anymore ( they just emailed me). I would love to use the stock one but its somewhat rusty and not sure about it. I thank everyone for their input I guess I am just going to have to call around locally and see what i can find if not looks like i am going to have more money wrapped up in my driveshaft than my rebuilt trans lol.
Old 10-17-2012, 05:20 PM
with the amount of straight jobs trucks around, finding a driveline shop should not be all that hard..
Old 10-27-2012, 09:31 AM
So I found a couple shops around I guess the going rate for a two piece driveshaft w carrier bearing is $600-$800 crazy
Old 11-02-2012, 05:21 PM
If your D/L is in good shape...The length is only gonna change on the front section of the 2 Pc..
Take both sections to a D/L shop and have the front section shortened, then have both sections balanced together.
************** a driveshaft rjhmustang Transmission - Rearend 1 05-08-2012 03:02 PM
How do i take off my driveshaft?? aztek_warrior Transmission - Rearend 4 05-09-2006 06:52 PM
driveshaft help!! stewwwy1 Transmission - Rearend 1 03-20-2004 10:08 PM
driveshaft cavkid Transmission - Rearend 2 04-22-2003 06:09 AM
driveshaft olesonjl Transmission - Rearend 1 11-14-2001 10:00 PM
