driveshaft? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2006, 07:35 PM
tombo615's Avatar
driveshaft?
hey guys, im relatively new to the whole hotrodding thing, i've been building a 69 cutlass for about a year now, and its almost about time to put my motor/trans into the car, its a bbc with a th400, going to a 12 bolt chevy rear
my question is do any companies offer driveshafts for cars in the aspect of what it is; i guess what im trying to say is do they offer lengths for specific cars, rather then just measuring? the car is an a-body so im assuming its a common driveshaft. also which driveshafts are stronger? i've got some power with the motor and dont want anything to twist. i heard aluminum is stronger; is this true? also can you guys recommend anybody online? thanks guys
Old 01-31-2006, 09:27 PM
Buy a steel shaft. Much easier to service and can be repaired at local driveshaft repair shop. Check Yellow Pages locally.
Measure for your car, then you leave NOTHING to chance!!
Old 01-31-2006, 09:33 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
measure for the length you need. have the drive shaft shop explain how they want it measured.
I have an Inland Empire aluminum shaft in my 61 Dodge Lancer with 350 chevy power. Top quality drive shaft
New Driveshaft Noise bjam2 Transmission - Rearend 6 08-26-2006 11:18 AM
Multi-section driveshaft ckucia Transmission - Rearend 23 05-07-2006 12:01 PM
1986 or somewhere around there s10 driveshaft angle problems fumplet Transmission - Rearend 10 01-16-2006 09:20 PM
short driveshaft high angle ujoints powerrodsmike Suspension - Brakes - Steering 16 02-09-2005 07:58 AM
Driveshaft measurement 71gtx Transmission - Rearend 6 01-11-2004 11:00 AM
