-   -   driveshaft angle? (http://www.hotrodders.com/forum/driveshaft-angle-104346.html)
JJ350 12-12-2006 01:01 PM
driveshaft angle?
Hi guys, this is my first post and i hope i don't start off with a stupid question but here it goes, and I did check knowledge base if i've overlooked the answer my appologies, anyway i've got a '86 chevy s-10 with a 350 sb . I was wondering if i was going to lower this truck is there a specific degree the driveshaft/rearend must maintain. The rearend looks like it has moved alittle already, the angle where the driveshaft goes into the diff looks alittle steep. I did by the truck about a year ago from my buddy, and I don't know any history of the truck. thanks.
OneMoreTime 12-12-2006 02:17 PM
Here are a whole bunch of threads on drive shaft and pinion angle..
http://www.hotrodders.com/forum/sear...earchid=762128
I will let you sort through all that and see if you question can be answered..
Sam
pasadenahotrod 12-12-2006 02:22 PM
The pinion angle must be maintained in parallel to the trans/engine shaft plane, u-joints should not exceed manufacturer's specs.
JJ350 12-12-2006 02:56 PM
Thanks guys , I found what I was looking for .
