driveshaft angle? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2006, 01:01 PM
JJ350's Avatar
driveshaft angle?
Hi guys, this is my first post and i hope i don't start off with a stupid question but here it goes, and I did check knowledge base if i've overlooked the answer my appologies, anyway i've got a '86 chevy s-10 with a 350 sb . I was wondering if i was going to lower this truck is there a specific degree the driveshaft/rearend must maintain. The rearend looks like it has moved alittle already, the angle where the driveshaft goes into the diff looks alittle steep. I did by the truck about a year ago from my buddy, and I don't know any history of the truck. thanks.
Old 12-12-2006, 02:17 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Here are a whole bunch of threads on drive shaft and pinion angle..
http://www.hotrodders.com/forum/sear...earchid=762128
I will let you sort through all that and see if you question can be answered..
Sam
Old 12-12-2006, 02:22 PM
The pinion angle must be maintained in parallel to the trans/engine shaft plane, u-joints should not exceed manufacturer's specs.
Old 12-12-2006, 02:56 PM
JJ350's Avatar
Thanks guys , I found what I was looking for .
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 32 05-11-2007 07:22 PM
Driveshaft angle butch27 Transmission - Rearend 5 10-20-2006 06:00 PM
Multi-section driveshaft ckucia Transmission - Rearend 23 05-07-2006 12:01 PM
1986 or somewhere around there s10 driveshaft angle problems fumplet Transmission - Rearend 10 01-16-2006 09:20 PM
short driveshaft high angle ujoints powerrodsmike Suspension - Brakes - Steering 16 02-09-2005 07:58 AM
