-   -   driveshaft angle (http://www.hotrodders.com/forum/driveshaft-angle-160954.html)
ratrod47 07-01-2009 07:44 AM
driveshaft angle
Hey guys, how critical is driveshaft angle? Dirt up rat rod project.
Frisco 07-01-2009 08:02 AM
The driveshaft angle is somewhat limited by the maximum available in the u-joints being used. Exceeding the limits will cause the u-joints to bind.
Some angle is needed to enable the u-joints to function as designed. The overall life of the u-joint will be greatly decreased when the driveshaft angle is at or near the maximum available for the u-joints. Extreme angles also will limit the working RPM.
For most street vehicle applications the transmission/driveshaft/pinion gear angle should be in the 3-5 degree range when at rest and at ride height for best performance and life.
richard stewart 3rd 07-01-2009 08:31 AM
Hi,
Just a short article about the effect of incorrect drive line angles.
Rich
http://www.streetrodderweb.com/tech/...les/index.html
