driveshaft angle - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2009, 07:44 AM
driveshaft angle
Hey guys, how critical is driveshaft angle? Dirt up rat rod project.
Old 07-01-2009, 08:02 AM
Frisco's Avatar
Glad To Be Here
The driveshaft angle is somewhat limited by the maximum available in the u-joints being used. Exceeding the limits will cause the u-joints to bind.
Some angle is needed to enable the u-joints to function as designed. The overall life of the u-joint will be greatly decreased when the driveshaft angle is at or near the maximum available for the u-joints. Extreme angles also will limit the working RPM.
For most street vehicle applications the transmission/driveshaft/pinion gear angle should be in the 3-5 degree range when at rest and at ride height for best performance and life.
Old 07-01-2009, 08:31 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Just a short article about the effect of incorrect drive line angles.
Rich
http://www.streetrodderweb.com/tech/...les/index.html
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 39 03-29-2015 09:02 PM
Driveshaft angle, how much is too much? LiftFlat Transmission - Rearend 3 08-07-2007 11:03 AM
driveshaft angle? JJ350 Transmission - Rearend 3 12-12-2006 02:56 PM
1986 or somewhere around there s10 driveshaft angle problems fumplet Transmission - Rearend 10 01-16-2006 09:20 PM
short driveshaft high angle ujoints powerrodsmike Suspension - Brakes - Steering 16 02-09-2005 07:58 AM
