Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Driveshaft angle
Old 10-19-2006, 09:06 PM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
Not sure if I understand what you are saying.
The theory is that the angle at each "U" joint should be the same.........So, if the angle from the trans to the driveshaft is 2* and the angle from the driveshaft to the rear is 2*, then you should be fine.
If you are saying that the rear end is facing dowm at the pinion and the trans is facing down at the back.....and the driveshaft is going upwards from the front to back........you are not OK...............although, you may not have a problem.
