Driveshaft angle, how much is too much? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2007, 10:16 AM
Building a '31 Dodge pickup with a 318/727 combo.
Rough mesurement tells me the drive shaft will be about 2 1/2 feet long.
I have the engine sitting about 3-4 degrees, as is the rearend, but they are on about a 9-10inch different plane...kinda like those guys with lifted 4x4's.
I'd estimate that the drive shaft angle will be 15-20*'s, easy enuogh to compensate with the perches on the rearend, but not a lot to do coming off the tranny.
What's my best way to approach this?
Leave it?
Angle the rear?
Look for a high pinion 9inch?
I don't want to set the engine and tranny down any further, and the Crank centerline is just about even with the top of the frame rail right now.
Looking for options before I start covering the chassis with sheetmetal
Thanks
Old 08-07-2007, 11:13 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Please do a search on the site about drive shaft angles and it may even be in the wiki..Sounds like waay too much difference to me to be very durable..
I blocked my chassis at ride height with the springs disconnected in order to figure this one out and had to lower the car quite a bit to get everything to work out..wound up with the chassis height about at the scrub line..BTW my driveshaft is about 15" long..
Sam
Old 08-07-2007, 11:32 AM
techinspector1's Avatar
Wiki Edits: 326
If you'll read through this and click all the links that are highlighted in blue, you'll get a pretty good education on u-joints, angles and driveshafts. This is the best article I've read on the subject.
http://alteredz.com/drivelinemods.htm
Old 08-07-2007, 12:03 PM
Good read on the link, looks like I'll have a bit of "adjusting" needed to get things right.
Thanks.
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 39 03-29-2015 10:02 PM
driveshaft angle? JJ350 Transmission - Rearend 3 12-12-2006 03:56 PM
Multi-section driveshaft ckucia Transmission - Rearend 23 05-07-2006 01:01 PM
1986 or somewhere around there s10 driveshaft angle problems fumplet Transmission - Rearend 10 01-16-2006 10:20 PM
short driveshaft high angle ujoints powerrodsmike Suspension - Brakes - Steering 16 02-09-2005 08:58 AM
