-   -   Driveshaft builder? (southern New England) (http://www.hotrodders.com/forum/driveshaft-builder-southern-new-england-230914.html)
31ROC 03-19-2013 09:46 AM
Can anyone recommend a driveshaft builder--Northern CT/Western Mass areas?
Thanks
33Willys77 03-19-2013 10:52 AM
Check out Dennys driveshafts. Dennys Driveshaft Street Rod Driveshafts affordably priced and custom built in your choice of steel or aluminum. High Speed High RPM Balanced for smooth running trouble free performance
gearheadslife 03-19-2013 10:57 AM
south shore bearing in quincy mass.
http://www.southshorebearing.com/driveshafts.htm
I've had 3 shafts made there..
Irelands child 03-19-2013 11:50 AM
I'll second Denny's Driveshafts - they do nice work and within reason, but not cheap.
This is mine: http://i70.photobucket.com/albums/i8...driveshaft.jpg
Dave W
31ROC 03-19-2013 11:52 AM
Whoah.....your right about "not cheap"!!!
gearheadslife 03-19-2013 01:02 PM
my shaft took dual shots of happy gas and high 9's
and they are local
Irelands child 03-19-2013 01:14 PM
Two new yokes, a new input spline, new shafting and assembled in proper time plus 2 HD u-joints along with balance are never cheap.
Your alternative is to find a shop that does truck driveline work, bring them a rusty and pitted junkyard drive shaft, a well used input spline and let them try to make the yokes that may be distorted work, then add someones unknown brand u-joints, balance this claptrap and pray it's going to be a good deal for you.
Universal Auto, N. Pearl Street in Albany NY will do a decent job for about $225+/- using your junk yard parts and new Spicer u-joints and is my usual alternative to Denny's, having made up several for me in the past.
gearheadslife 03-19-2013 02:56 PM
wrong, 300 bones for an all new thick wall 3" shaft, local with spicer joints and new ends, the trans yoke they'll tell you if it's junk..
they used my old just for measurment.. nothing old used.. no need to get from an out of state shop.
AutoGear 03-20-2013 09:06 AM
Call Magnus Racing Products in Danielson CT. He has PST (?) driveshafts; all new steel, 3" dia I believe; comes with new U-joints and a yoke. If you need a custom length; he'll order it for you. Expect it to be in the $200-$250 range. When you call; ask for Mike Sangermano. Tell him Nate from Auto Gear gave you his name
Mods: can I post the phone number?
31ROC 03-20-2013 09:13 AM
Thanks for all the replies!
Going with "south shore bearing "....very well recommended, and very reasonable.
Cape Cod Bob 03-20-2013 08:05 PM
Very good ans very reasonable. Just be sure you are on the same page with the length. I downloaded Denny's printable diagram on how to measure. Helped a lot.:welcome:
