Driveshaft builder? (southern New England) - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2013, 09:46 AM
31ROC's Avatar
Can anyone recommend a driveshaft builder--Northern CT/Western Mass areas?
Thanks
Old 03-19-2013, 10:52 AM
33Willys77's Avatar
Check out Dennys driveshafts. Dennys Driveshaft Street Rod Driveshafts affordably priced and custom built in your choice of steel or aluminum. High Speed High RPM Balanced for smooth running trouble free performance
Old 03-19-2013, 10:57 AM
Banned
south shore bearing in quincy mass.
http://www.southshorebearing.com/driveshafts.htm
I've had 3 shafts made there..
Old 03-19-2013, 11:50 AM
Irelands child's Avatar
I'll second Denny's Driveshafts - they do nice work and within reason, but not cheap.
This is mine:
Dave W
Irelands child
Old 03-19-2013, 11:52 AM
31ROC's Avatar
Whoah.....your right about "not cheap"!!!
Old 03-19-2013, 01:02 PM
Banned
my shaft took dual shots of happy gas and high 9's
and they are local
Old 03-19-2013, 01:14 PM
Two new yokes, a new input spline, new shafting and assembled in proper time plus 2 HD u-joints along with balance are never cheap.
Your alternative is to find a shop that does truck driveline work, bring them a rusty and pitted junkyard drive shaft, a well used input spline and let them try to make the yokes that may be distorted work, then add someones unknown brand u-joints, balance this claptrap and pray it's going to be a good deal for you.
Universal Auto, N. Pearl Street in Albany NY will do a decent job for about $225+/- using your junk yard parts and new Spicer u-joints and is my usual alternative to Denny's, having made up several for me in the past.
Irelands child
Old 03-19-2013, 02:56 PM
Banned
wrong, 300 bones for an all new thick wall 3" shaft, local with spicer joints and new ends, the trans yoke they'll tell you if it's junk..
they used my old just for measurment.. nothing old used.. no need to get from an out of state shop.
Old 03-20-2013, 09:06 AM
Call Magnus Racing Products in Danielson CT. He has PST (?) driveshafts; all new steel, 3" dia I believe; comes with new U-joints and a yoke. If you need a custom length; he'll order it for you. Expect it to be in the $200-$250 range. When you call; ask for Mike Sangermano. Tell him Nate from Auto Gear gave you his name
Mods: can I post the phone number?
Old 03-20-2013, 09:13 AM
31ROC's Avatar
Thanks for all the replies!
Going with "south shore bearing "....very well recommended, and very reasonable.
Old 03-20-2013, 08:05 PM
Cape Cod Bob's Avatar
Very good ans very reasonable. Just be sure you are on the same page with the length. I downloaded Denny's printable diagram on how to measure. Helped a lot.
Cobra builder, kit car builder, slightly retired DocCobra Hotrodders' Lounge 1 01-21-2012 07:18 AM
Hi from england joe90 Introduce Yourself 7 12-18-2009 04:00 PM
Hello From England... RoadHouse Tim Introduce Yourself 6 11-05-2008 04:48 AM
Hi From England Willysangel Introduce Yourself 2 10-04-2006 10:26 PM
Motor builder in southern california???? bigbad66chevelle Engine 4 03-24-2003 06:54 AM
