Driveshaft center support bearing ? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-10-2007, 02:35 PM
scrot's Avatar
Mark, so what are you going to do about the bearing?
  #17 (permalink)
Old 07-10-2007, 08:22 PM
markzepp820's Avatar
carrier bearing
well...I'm gonna buy a new bearing and have it pressed on hopefully...poeple are telling me it can be done...the old bearing hardly spun, it needed replaced.
Here are some pics of part of my driveshaft where the bearing goes on...Anyone else's driveshaft look like this, when putting a new bearing on?
ID:	22699   Click image for larger version
ID:	22700   Click image for larger version
  #18 (permalink)
Old 07-11-2007, 05:17 AM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
I've never seen one that bad, but hey, Duct Tape and a bit of WD-40 and it'll be good as new....
In a while, Chet.
  #19 (permalink)
Old 07-11-2007, 06:44 AM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Yee haw !
It almost looks like the inner race might be welded to the shaft in that case there will be alot more work .
It is really hard to tell from pix.
Hopefully it will just pop right off.
keep us posted
R
"SlowRide66"
"Illegitimis non carborundum"
  #20 (permalink)
Old 07-12-2007, 09:45 PM
another question
another question here....how do i know what size bearing i need? auto stores want to know what series i have(how am i supposed to know?). Do i measure something? Fill me in..
thanks
  #21 (permalink)
Old 07-12-2007, 10:41 PM
Jmark's Avatar
Usually, the series is the type of truck it is, as in C-10, C20 and so on.
the piece that is still on the shaft (where your finger is pointing) is the inner race of the carrier bearing. There is also a retaining ring that you can easily split with a hand chisel and hammer and knock off. Those 2 pieces MUST come off before pressing on the new one! LOL
Do you have an air chisel? If so, use a small torch and heat the race then put the chisel in the ball groove and try hammering it off the shaft. If it comes off, clean the shaft good and lightly sand the shaft with some fine paper or emry cloth. Just get it good and clean, then use the pipe to tap on the new one or just break down and carry it into a machine shop and have them press the race off and install the new one for ya.
mark
  #22 (permalink)
Old 07-13-2007, 12:24 AM
thanks
lol...i feel dumb...i didn't relize that had to come off. I thought it was permanent...thats why i was doubting, getting the bearing on. thanks jmark, i understand now..lol.
  #23 (permalink)
Old 07-13-2007, 08:14 PM
mission accomplished
i had a machine shop remove and press the new bearing on. Put it together and drives great!
thank you all for your help and input...
thanks,
mark
  #24 (permalink)
Old 07-14-2007, 05:51 PM
fast68's Avatar
likes chevy trucks & boobies
i always just drop it off at the shop and let them do all the work, its cheap labor anyways
  #25 (permalink)
Old 07-15-2007, 06:52 AM
Have you considered going to a 1 piece shaft?
Shane
oops you already got it fixed
SBC Pilot Bearing Brian's56Chevy Transmission - Rearend 1 07-04-2007 08:23 AM
Need help finding a rod bearing for the youngsters Hot rod 62CHEVYC10 Engine 2 04-10-2007 07:54 PM
Transmission Support jackodom Suspension - Brakes - Steering 2 12-19-2006 10:47 AM
s-10 carrier bearing, how do you check them catscan4free Transmission - Rearend 2 01-24-2004 04:45 PM
Nova Driveshaft Length 68NovaSS Transmission - Rearend 2 01-20-2003 09:19 PM
