Driveshaft depth in tail housing - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2013, 01:33 AM
sqeezeit's Avatar
Just wondering everyones thoughts on how much the drive shaft should be on the tail shaft.I measured my shaft(drive shaft part that goes into tranny) and was 3 5/8" and when at ride height is only in 1 1/4" of spline contact seems really low to me.Its a th400 tranny on a mild 350 chevy small block.Was this way when I bought it and seemed to be ok driving but seems low or I should say I dont like it.I plan on getting lengthened 1 3/4" but just wanted to see what everyone else thought about it.Thanks
Old 06-10-2013, 04:11 AM
S10xGN's Avatar
Gotta love a turbo!
It should stick out about 3/4" of an inch from fully bottomed.
Russ
Old 06-10-2013, 04:40 AM
BOBCRMAN@aol.com's Avatar
Depends on yoke. A lot of prople use the truck type yoke that isn't designed to slip. This has to be set up with short spline engagement.
Old 06-10-2013, 02:15 PM
sedanbob's Avatar
Make sure it doesn't bottom out at any point in your suspension travel.
Old 06-10-2013, 05:14 PM
Russ
X2
3/4 to 1 inch is normal
Old 06-11-2013, 01:01 AM
sqeezeit's Avatar
I I kinda thought I heard the 3/4 - 1" rule b4.going to have it lengthened, thanks guys
Old 06-11-2013, 01:02 AM
sqeezeit's Avatar
O and forgot to mention its a slip yoke type
Old 06-11-2013, 02:04 PM
chevymike's Avatar
Remember, the 3/4-1" part is AT ride height.
Old 06-12-2013, 06:01 AM
Pats55's Avatar
I had one come loose, it looked slightly short,I figured it'll probably be okay. The mistake I made I went like hell across the bumpy section of the road and damn thing fell out. Dig around and see if you can find a longer yoke,.there are different distances in the joint section, cheaper than getting it lengthened
Ready to fill the gap from C4 tail housing to 9" rear Gary Loptien Suspension - Brakes - Steering 4 03-01-2012 11:03 AM
T-700R4 tail housing bushing replacement? Scottsdale Transmission - Rearend 1 01-28-2011 05:43 AM
Tail Shaft Housing...Long or Short??? lt1_performance Transmission - Rearend 4 07-11-2007 11:14 PM
th350 tail shaft / extension housing switch 72BuickGS350Conv Transmission - Rearend 2 10-23-2005 09:34 PM
4L60E tail housing seal leak bluesman123 Transmission - Rearend 13 01-31-2005 11:54 PM
