For every success story with a homemade drive shaft i will show you 25 that did not work and caused damage to pinion bearings,vibrations,broke and tore the floor up and eats u-joints. Could you get away with it ?? Maybe.. but if you had a driveshaft made you would not beleive how much smoother your ride car /truck would be. Save your pennys and have it cut by a driveline shop.Around here i buy brand new balanced driveshafts for 185-240 depending on the application(thats with joints and a new yoke) Cut rebalance about 100 bucks so....i allways go new.Like i said you wont beleive the diff,plus your going to have to be a pretty good weldor to stick weld a shaft. Dont forget to take a tape measure with yah to the wreckin yard...sometimes you do find the correct length. Good Luck
