Driveshaft length ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2003, 11:33 AM
What do you think the minimum length of a driveshaft could be? It looks like mine will be around 12 inches if I set it up with a Turbo 400 from the Caddy.
I could swap out the tail shaft for a short one and that will make it about 10 inches longer.
Should I swap out the tail?
Old 09-04-2003, 12:17 PM
302 Z28's Avatar
Lenght is not an issue, as long as the angle isn't too great.
Vince
Old 09-04-2003, 12:31 PM
slider in wa's Avatar
Slider in Wa.
HOW ABOUT SEVEN iNCHES?
The drive shaft in My 48 Chev COE is approx 7 inches. It is not a problem as it has the correct input out put angle. Have a wonderfull day!!
Slider in Wa.
Old 09-04-2003, 02:55 PM
Thanks guys, That is kinda what I thought. I will be sure to set the angles as close to the stock Jag rear end as I can.
Time for a fact finding misionat the local Pick-a-Part.
