Driveshaft length and balance - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2003, 02:41 PM
New Member
Post Driveshaft length and balance
If a driveshaft has to be cut and rebalanced, how should the measurement be taken to get the exact length and fit? Only needs to be and inch or two shorter. I am replacing a Powerglide with a TH400 in a 71 Chevelle.
Old 01-30-2003, 03:19 PM
Seon's Avatar
Post
If your drive shaft was already on the car with the powerglide and you change the transmission to a 400, just measure the length of the powerglide and the measurement of the 400. Then cut the drive shaft using the difference of the two lengths. BTW measure from the flange of the transmission where it bolts to the engine to the end of the tailshaft.
[ January 30, 2003: Message edited by: Seon ]</p>
Old 01-31-2003, 02:19 PM
onebadmerc's Avatar
I need a bucket of arc sparks
Post
Take your yoke off of the driveshaft, slide it into the transmission all the way then pull it back out 1/4 to 1/2 inch. Then take your tape and measure fron the center of the U joint cap in the yoke to the center of where the other U joint cap sits in the rearend. Make sure all four of your tires are on the ground when measuring, the way it will be when your driving it, or your measurement will be off.
Old 01-31-2003, 02:56 PM
dmorris1200's Avatar
doesn't play well with others
Post
If I remember correctly I slid mine out about an inch and measured. No problems so far.
BUILT FORD TOUGH
Old 01-31-2003, 03:36 PM
onebadmerc's Avatar
Post
I might be wrong on the 1/4 to 1/2 figure, too think about it I think the driveshaft shop told me 1/2 to 1 inch. It has been a year since I had the driveshaft shortened and my memory isn't as good as it use to be. I am sorry if I gave you the wrong measurements edubois.
Old 01-31-2003, 04:42 PM
Post
I don't know what the 'text book' measurement would be. I'm not even sure how I did it was right, but it's working. I measured how far out the yoke was from bottoming out with the 8-inch rear still in the car ( which was about an inch) and then set the yoke the same and measured for the 9-inch rear. So far so good.
BUILT FORD TOUGH
Old 01-31-2003, 05:20 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
If you slid the yolk all the way in the transmission and measure from the center of the yolk cap to the center of the rear cap and give this to your driveshaft shop, they will add the correct slide clearance. That said, most of them use 1".
Chris
Old 02-01-2003, 12:00 PM
New Member
Post
Thanks everybody, good info...
